by XenosPilot » Sat Feb 03, 2018 11:51 am
I am looking to improve the baffle seals on my Xenos w/ Aerovee and would like to know what kind of seal material others are using. I am using standard silicone seals on the upper fence, but I am having trouble with the front ones that seal around the cowl openings. I think I would like to use the material that Sonex sells in their kit, but I already have the fence made and installed (from the original builder) and don't need the kit...just the seals. Can someone tell me what material Sonex uses so I can buy it? Optionally, is there any other seal material of a similar design that works better? I am hesitant to put the silicone "flap" style seals on the cowl openings because the flaps are oriented in the wrong direction...causing the flaps to open up and bypass air.
Thanks!
Stephen Layton
Xenos, Aerovee, Aeroinjector, 100LL, MGL Enigma panel
Prefer motorless flying...soaring!
Hobbs, NM
