PFH Sonex B
PFH Sonex B
Postby pfhoeycfi » Wed Feb 07, 2018 5:37 pm
I just received my B tail kit and don't know what to think of the one skin. There are long scratches from one end to the other...not a couple...many...almost the entire surface on one side. This wasn't a transport issue, the shipping boxes were in perfect condition. I am curious as to the quality of the skins other builders have received. I am disappointed.
pfhoeycfi
Re: PFH Sonex B
Postby lpaaruule » Wed Feb 07, 2018 6:15 pm
The only scratches I remember seeing are ones created during the leading edge forming process. They weren't deep, and could easily be "buffed" out.
Are your scratches deep enough to easily feel with your fingernail? Would they show up in a picture?
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Re: PFH Sonex B
Postby pfhoeycfi » Wed Feb 07, 2018 6:32 pm
Yes they show up quite good in the pics I took and you can def feel them as well.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: PFH Sonex B
Postby WaiexN143NM » Wed Feb 07, 2018 7:57 pm
Hi guy,
Just email sonex and attach the pics. I'm sure they'll take care of you.
Re: PFH Sonex B
Postby pfhoeycfi » Mon Mar 26, 2018 12:24 pm
I had to drill out a CCP rivet on the rudder where the skin secures to the top rib. The hole is now a little too loose for a 1/8. Having trouble locating similar CCP rivets the next size up, 5/32. Spruce doesn't seem to carry them, Wicks is out of stock. Can anyone recommend a source?
peter
doylestown, pa
Peter Hoey
pfhoeycfi
Re: PFH Sonex B
Postby WaiexN143NM » Mon Mar 26, 2018 7:16 pm
hi peter,
ace hardware store, most carry stainless steel pull rivets. in 1/8, and 5/32 diameters. Lengths of 1/8, 1/4, 1/2. they will be with the other Arrow products, ie staple guns etc. made in china like everything else, but the quality is good. just as good as the sonex or aircraft spruce rivets. they come in small packages of 25, for $5 out the door w tax.
good luck!
waiexN143NM
michael
Re: PFH Sonex B
Postby pfhoeycfi » Mon Mar 26, 2018 8:01 pm
WaiexN143NM wrote:hi peter,
good luck!
waiexN143NM
michael
Great, that was too easy ...
will check Ace out tomorrow,
thanks,
peter
Peter Hoey
pfhoeycfi
Re: PFH Sonex B
Postby tljones42 » Tue Mar 27, 2018 8:37 am
I found CCP52s at Columbus Fasteners, http://www.colfast.com/detail.aspx?item=CCP52&id=5850
Tom Jones
Onex 0133
tljones42
Re: PFH Sonex B
Postby sonex1678 » Tue Mar 27, 2018 10:35 am
CCP52's and CCP62's also available from K.L. Jack Industries and Supplies (KLJACK.COM)--nice quality to boot.
Douglas B Scripture
Sonex 1678
sonex1678
Re: PFH Sonex B
Postby WaiexN143NM » Tue Mar 27, 2018 11:40 am
hi all, tom, doug,
just curious, where are you using those long rivets, 52 & 62? are they 1/8 in diameter?
all i remember is the 48’s during our build.
thanks
michael.
Return to Sonex-B / Waiex-B
