by Kai » Sat Jan 13, 2018 2:03 am
Same happened to me on my standard gear Sonex #0525 with a 22A. It is so old that it has the engine mount with the thin walled tubing. At apprx 500 hrs the lower left support broke. Repair was much like shown in Stuart's narrative (great, by the way): just a little inside dressing with a 1/2" round file, one long high grade steel ø14mm pipe with 2mm wall thickness rammed down the mount structure, with liberal amounts of high temp Hysol, after cleaning and degreasing everything inside-out. It has been sitting there ever since. To quote Kerry: "Grass fields- certainly. But rough grass fields- no!". Watch your labding gear retainer bolts!
