petep wrote:Been trying to tune my Aeroinjector for several weeks with little success. Started with a #2 need could get anywhere near WOT before the back two cylinders blew thru 1400 EGT. Went to a 2.5 and saw some improvement but still the same issue with rear cylinders high EGTs. Now on a #3 needle any can get the back two cylinders to WOT at 1385 or so while the front two are barely 1200. Suspect a bogus EGT indication but not willing to fry the engine based on that assumption. I have double checked the usual suspects, ie induction leaks, valve lashing, ignition timing, leak down check and mixture arm position and travel.
Sent all this data to Sonex yesterday but don't expect to hear from them until after the holidays. Anyone think of anything else I might check in the interim?
petep wrote:Now on a #3 needle any can get the back two cylinders to WOT at 1385 or so while the front two are barely 1200 at full rich mixture.
Users browsing this forum: No registered users and 53 guests
