pgerhardt wrote:The #3 pin says .196-.317"
The #2 pin says .141-.255"
the #4 pin says .-250-.355
The #3 reamer says .3099" to 0.4510".
The #2 reamer says .2474" to .3781"
The #4 reamer says .3474" to 0.5017"
pin numbers are from Aircraft Sprucehttps://www.aircraftspruce.com/ca ... perpin.php
I am reading C and D demensions.
Reamer specs from https://www.aircraft-tool.com/shop/search.aspx
I don't think I am understanding the demensions correctly
bvolcko38 wrote:I have the taper pin reamer and am done with it...waiting to pass it on. Just need an address
BV
.WaiexN143NM wrote:Hi all,
The spring loaded link will allow for rod link length changes as the tailwheel rod flexes.
Cheers
WaiexN143NM
pgerhardt wrote:bvolcko38 wrote:I have the taper pin reamer and am done with it...waiting to pass it on. Just need an address
BV
Bill is it a number three or number two?
Paul
Users browsing this forum: Google Adsense [Bot] and 13 guests
