Waiex 49 wrote:Nice job on your toe brakes and castoring tailwheel!
I installed the toe brakes with the Sonex disc brakes.
I just received a full swivel tailwheel from Fly Boy Accessories and plan to install it soon.
Dfferential braking was a big improvement and I am looking forward to having a full swivel tailwheel on my Waiex.
Fly safe,
Don Bowen
Viking Waiex N49YX
sonex892. wrote:I installed toe brakes a few months ago. I copied John Gillis's idea (Thanks John). The fuel valve is in the way on my plane so I made a mirrored, left and right set of pedals.
Soon after the brakes were sorted I started working on a fully castoring steerable tailwheel. I replaced a stock standard 4" tailwheel and steering pushrod, which after 700 + landings were still in remarkably good shape. The price of that simplicity is noise, rough ride and huge turning circle.
I've only flown a few times with the tailwheel, but so far so good. I had some help from Peter Anson for the wheel design. I used the same size wheel and pnuematic tire as Pete sells. Rod ends on the steering arm are Aurora CM-4S, no bending of the rod was required. Used a #2 taperpin to connect the pivot shaft to the castor.
The benefits are, Taxying maneuverability It can turn on a dime if needed. Smoother and quieter ride and increased visibility. I dont have to pick up the tail any more to move it around the hanger. My major concern was raising the tail so high, that turned out to be a non event.
Total weight increase over the stock tailwheel, 400 grams.
Users browsing this forum: T41pilot and 12 guests
