1labelloj wrote:I have the hydraulic brake option. There are conflicting instructions in the original plans vs the plans sheet that came with the upgrade parts. The original plans say to use 3 AN3-15A bolts (3/16 diameter) through the main brake body (calipers) and the wheel pant plate with one thru the eye/tip at the bottom of the axle.
On the inserted plans sheet it calls for ONLY ONE fastener thru the main brake body (calipers) and the wheel pant plate going thru the eye/tip. There it is calling for a MS20392-3C49 clevis pin which has a I/4inch diameter. The main brake body has pass through holes which at 1/4 inch. The eye/tip at the bottom of the axle has a 3/16 hole and not much metal which make me concerned about opening to 1/4 inch.
Any advice? I am concerned also with only using a single clevis pin as opposed to 3 clevis pins or bolts.
Users browsing this forum: WolverineYX and 78 guests
