kmacht wrote:I highly recommend the headsets inc ANR conversion kit if you have a set of non ANR headsets you want to use in a Sonex. I bought the kit out at airventure two years ago and did the conversion right at my campsite in Scholler. The ANR makes a world of difference in the Sonex. They probably can't compete with a Bose but they aren't $1000+ either. With them on I don't find the noise in a sonex that bad at all.
kmacht wrote:My biggest complaint is the vibration. On the flight out and back to Oshkosh I actually got some blisters on my heels from the balls of my feet sitting on the floor with my toes on the rudder pedals for 10 hours. I recommend putting a thin pad of memory foam under a piece of carpet there if you haven't yet installed your interior.
Corby202 wrote:The 2200 Jab in my Sonex is way quieter than an unmuffled VW. In my Corby Starlet I had to use earplugs as well as my ANR headset on long flights. I also think using a noise deadener/ heat shield on the inside of the firewall helps a lot.
Something you said made me wonder what frequency is it that is most annoying / painful? And it would be cool if we could run the study again to see if any of the different mitigation arrangements affected the target frequency range.
I haven't done it yet but putting something in the opening between the cockpit and the tail cone between the #1 turtledeck formers will help cut down on the noise as well. The open tailcone section acts like a giant megaphone aimed straight at your head. I think Sonex used to sell a fabric cover that went over this area. Not sure if they still do or not.
Corby202 wrote:Hi Steve. Yes I fitted a muffler.http://www.mykitlog.com/users/display_l ... 4458&row=2
I do get comments about how quiet the plane is flying overhead.
As funny as it sounds my Sennheiser headset works well, it works even better straight after I have had a haircut.
peter anson wrote:kmacht wrote:My biggest complaint is the vibration. On the flight out and back to Oshkosh I actually got some blisters on my heels from the balls of my feet sitting on the floor with my toes on the rudder pedals for 10 hours. I recommend putting a thin pad of memory foam under a piece of carpet there if you haven't yet installed your interior.
Can I suggest you look again at prop balance? Can't guarantee a dynamic balance will help but it might. The last time I did a static balance it was so good that a dynamic balance couldn't improve on it but a few years ago I had a problem with low speed vibration around 1500 rpm. A dynamic balance by Xenos builder, Brian Rebbechi, totally eliminated it. It is important for more than just comfort. Bad vibrations are high frequency loads that could reduce the fatigue life of parts of the airframe.
Users browsing this forum: Bing [Bot] and 126 guests
