Wing Instillation
Wing Instillation
Postby Arnieb » Wed Jul 12, 2017 9:25 am
I just purchased a flying Sonex with only 1 hour on it, So I had to trailer it home. The Problem I am having installing the wing is to get the Spar bolts holes to line up. Does anyone have any tips for doing this?
Arnieb
Re: Wing Instillation
Postby Waiex 49 » Wed Jul 12, 2017 9:41 am
i made a set of taper pins from 3/8" carriage bolts. I used a bench grinder to taper them down.
I could never get the wings lined up perfectly enough for the bolts to go in, but I can get the wings to line up close enough so that I could get the taper pins to go in and they slide in and get the wings completely lined up.
I drive the taper pins in from forward of the spars, then I put in the bolts from aft of the spar and they drive out the taper pins.
Sonex has recommended trailer hitch pins instead of the bolts. That's what I use.
Check out my web page http://www.mykitlog.com/donbowen. Look on the menu on the right of the screen called "Moving". It has all my experiences moving and assembling my Waiex and shows the taper pins.
Best of luck with your Sonex.
Don Bowen
Viking Waiex N49YX
Waiex 49
Postby Bryan Cotton » Wed Jul 12, 2017 10:00 am
Also, if you have glider pilot friends, ask them to help. Rigging wings is part of that dance.
Postby wlarson861 » Wed Jul 12, 2017 11:14 am
you need to have two helpers that can lift the wing tips a little while you insert the bolts. Sitting in the spar box the tips drop a fraction of an inch which is enough to allow the holes to miss-align.
Bill Larson
N861SX
wlarson861
Postby jowens » Wed Jul 12, 2017 11:28 am
Consider installing only the right wing first and starting the pins from the back. Install the right fuse pin first. Look in the left wing spar box to verify the pins are not inserted too much then install the left wing setting the left side pin first then the right.
Jim Owens
Dynon HDX1100, dual controls, Viking 110, taildragger
800 Hours, first flight 10-17-2018
jowens
Postby sonex892. » Thu Jul 13, 2017 3:06 pm
Are you trying to do it with the wing root rubber trim in place? I need to remove the h trim then put it back on after the bolts are in.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby harry56 » Wed Jul 19, 2017 10:37 pm
I may have to try that next time. I did try to lean the mixture a bit, but not a bunch. I don't usually just try to land, fuel, and go, but I'm expecting to fly from Dayton to Phoenix next summer, and I really don't want to add 7 hours just for extra time at refueling stops to cool off. I want to make sure I can stop, stretch my legs, hit the restroom, refuel, and continue on.
คาสิโนออนไลน์
harry56
Users browsing this forum: WolverineYX and 111 guests
