by MichaelFarley56 » Tue Jul 11, 2017 2:45 pm
It may not be necessary to remove the controls for painting but I bet you'll ultimately get a much better paint job if you do. For the amount of time it takes to remove them, you can then prep and paint the spar channels and all sides of the surfaces much easier.
Also remember the ailerons are counter weighted so you may have to rebalance them after paint to avoid the chance of flutter.
Ultimately though, I'm sure it can be done either way. Good luck!
Waiex #0056 - N569KM
Jabiru 3300A #1706
