Titanium Cranium wrote:I have the same issue, except that when I turn off the electronic ignition, the noise almost entirely goes away. I have the shielded p-leads that appear to be grounded at each end, but it's still very bad. I have an ICOM IC-A200 radio mounted just below my mag and electronic ignition switches. I can hear everyone else's transmissions, although the static is horrible. My transmissions are barely audible to others though. I wondered if it's because my plane has the headset jacks mounted just behind my shoulders, so there's 4-6 feet of un-shielded wiring that could be picking up the noise.
Titanium Cranium wrote:I bought a Sporty's SP-400 handheld radio to see if that worked any better, and I was amazed to find that the electronic ignition even feeds through into the handheld despite no connection to the plane at all. When I switch the electronic ignition off, the noise goes away in the handheld too. I'm going to try to get shielded wiring for the headset jacks and I'll move them under the panel to reduce the amount of wiring that's exposed to the electronic noise. If that doesn't work I'm not sure what to do short of ripping the entire panel out and starting over from scratch with a new radio and all new wiring to everything.
WaiexN143NM wrote:Hi all,
Dont forget to use shielded wire to the PTT buttons too.
Tom , first i would remake your headset jack harness and use shielded wire. All the other points mentioned good advice, ie p leads grounded one end only, isolation washers on jacks, etc.
i think you will like the results.
Efis throw out alot of RF also. We have a dynon skyview that emits alot. Ian from Xcom radio said that one of the worst is MGL. Not knocking their equipment, many people happy with their products. Just repeating what a radio mfgr told me.
We had the same problem, jacks mounted behind. Had to use shielded wire the second time around.
We too tried a handheld in cockpit, lots of RF from the efis.
WaiexN143NM
Jab 3300
Users browsing this forum: WolverineYX and 109 guests
