canopy bows
canopy bows
Postby Onex93 » Mon Apr 03, 2017 2:57 pm
Hello,
I've been struggling to get the canopy bows to adhere to the shape of my plywood templates. Does anyone have any guidance/ alternatives?
Thank you
Onex93
Onex93
Re: canopy bows
Postby Mike53 » Mon Apr 03, 2017 7:21 pm
This is how I did it. http://www.onexmike.org/canopy.html
Mike
Mike
Antoine de Saint-Exupery
Mike53
Re: canopy bows
Postby thomasjones42 » Tue Apr 04, 2017 8:28 am
"I've been struggling to get the canopy bows to adhere to the shape of my plywood templates. Does anyone have any guidance/ alternatives?"
I finally gave it up and just bought a tubing bender.
Tom Jones
Onex 0133
thomasjones42
Re: canopy bows
Postby gcm52 » Tue Apr 04, 2017 10:38 am
thomasjones42 wrote:"I've been struggling to get the canopy bows to adhere to the shape of my plywood templates. Does anyone have any guidance/ alternatives?"
Tom Jones
Onex 0133
What did you buy? There seem to be a lot of options from cheap to expensive for tubing benders?
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: canopy bows
Postby tljones42 » Thu Apr 13, 2017 11:37 am
Tom Jones
Onex 0133
I actually bought a conduit bender at the local hardware/electrical supply store. I have two tubing benders, neither of which are large enough to accomodate the canopy bows.
tljones42
Re: canopy bows
Postby sonex892. » Thu Apr 13, 2017 6:11 pm
If the Onex bows are similar to the Sonex that is big radius bends you shouldn't need a bender. All I did was screw a couple of wooden blocks onto a flat table a few inches apart and did like this bloke does bending heavy square tube.
https://www.youtube.com/watch?v=VO-OatK4HzI
As with all metal, will need to slightly overbend to allow for springback.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Re: canopy bows
Postby DCASonex » Fri Apr 14, 2017 11:57 am
Did same as Steve, works fine. If concerned about kinking the tube, screw a 7/16" bolt in one end, fill FULL with sand, screw second bolt in other end. Be sure to allow about 6" tangent each end to cut off after bending. Assuming original A model, if not already doing so, push windscreen bow up as far as possible with supplied Lexan material. Makes for a bit more headroom and cleaner line.
DCASonex
Return to Onex
Users browsing this forum: No registered users and 20 guests
