jjbardell wrote:He strongly recommended moving to a matched / forged 90.5mm bore as it doesn't require new heads or block. It increases wall thickness, helps with torque, and significantly improved cooling, which should result is much longer head life. The 375-400 degree + temps on climbs are putting too much stress on the heads between 1 and 3.
markschaible wrote:The AeroVee uses thick-walled 92mm cylinders that require machining the case and heads.
Users browsing this forum: Bing [Bot] and 24 guests
