Control stick forward throw
Postby Darick » Mon Feb 06, 2017 9:31 am
I added 2" to the bottom of my instrument panel, as many do, and wondering if the control stick must be short enough to go under or at least not hit the instrument panel. I purchased the Sonex grip and will be attaching it soon to the control stick. I'm a week or so from putting the tail on so I don't know how much movement is needed.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Control stick forward throw
Postby Bryan Cotton » Mon Feb 06, 2017 10:44 am
My subpanel is 2.5" high. My sticks clear by an inch or so. I plan to use a bike grip on the stick.
Postby radfordc » Tue Feb 07, 2017 12:35 pm
Darick wrote:I added 2" to the bottom of my instrument panel, as many do, and wondering if the control stick must be short enough to go under or at least not hit the instrument panel. I purchased the Sonex grip and will be attaching it soon to the control stick. I'm a week or so from putting the tail on so I don't know how much movement is needed.
You plan on doing outside loops? I don't recall needing all the down elevator throw ever.
radfordc
Postby Darick » Tue Feb 07, 2017 3:12 pm
No outside loops, ever, for me.
Thanks for all the replies. I posted pictures in the photo album section.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby SonexN76ET » Tue Feb 07, 2017 6:04 pm
Darick,
Your stick will have to demonstrate full range of motion between all the stops. The DAR or FAA inspector will check to see that it has free movement between all the stops and that you have a full range of deflection for your elevator and ailerons. If you ever or a subsequent owner ever brings it to an A&P for a condition inspections, the A&P will also check for full range of motion and deflection.
In practical terms, you would also hate to be practicing stall recoveries and have the stick get bound up underneath the instrument panel.
Jake
Sarasota, Florida
SonexN76ET
Postby fastj22 » Tue Feb 07, 2017 10:09 pm
I use full forward stick to get the tail flying on takeoff roll. The only other time full forward stick is used is to dislodge wayward cross country Cheetos from the bowels of the seat pan. Accidently, of course.
Postby DCASonex » Wed Feb 08, 2017 12:41 pm
If you will have any button on top of your stick, Push-to-talk or trim or ??, make sure there is room for that AND your thumb.
If your grip will adds to height, can slightly shorten the tube by similar amount.
Postby dynomike » Thu Feb 09, 2017 3:33 pm
I cut mine down .the dar did check my control throws .need every bit of throw to match plans
dynomike
Users browsing this forum: Google [Bot] and 46 guests
