fastj22 wrote:On the outboard end, I took a clevis pin and drilled and tapped a hole down its length. The pin slides inside the axle and is held in place with the cotter pin going through the castle nut holding the wheel on. The pant is attached to the threaded hole in the pin.
vwglenn wrote:I probably should've specified the outboard side. Inboard will be pretty easy.fastj22 wrote:On the outboard end, I took a clevis pin and drilled and tapped a hole down its length. The pin slides inside the axle and is held in place with the cotter pin going through the castle nut holding the wheel on. The pant is attached to the threaded hole in the pin.
I thought of something very similar. Just to confirm, all you have holding that clevis pin in place is the cotter pin? Seems simple enough. I knida like it but have reservations about sheering that cotter pin.
I thought of something similar but running it down the length of the axle and using the existing bolt on the inboard side to hold it in place. Or maybe a threaded rod and just using a nut on the outboard side.
fastj22 wrote:Found this too, if you don't mind spending some money.
http://www.aircraftspruce.com/catalog/h ... xelnut.php
Users browsing this forum: Google [Bot], wlarson861 and 140 guests
