Gusset not required
Gusset not required
Postby Concorde » Sun Dec 11, 2016 3:27 pm
Plan says that no Gusset required for rib number 5 but the W16-05 rib comes predrilled for 07 Gusset but no Gussets included.
Also ribs 1 through 5 fit the spar caps nicely but according to the plan we need to trim them more,why ? Am I missing something ?
Ben
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Re: Gusset not required
Postby samiam » Sun Dec 11, 2016 3:33 pm
You are correct, if I recall there are only gussets for ribs 1-4.
You will need to trim ribs 1-5 to allow them to fit under the spar caps, as outlined in the plans. Rib 1 gets trimmed the most, and they get trimmed less and less through rib 5.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby Concorde » Sun Dec 11, 2016 5:00 pm
The ribs 1-5 fit fine under the spar caps. My kit is # 1684 ,wondering if that makes any difference.
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby lstinthot » Sun Dec 11, 2016 8:52 pm
Sounds like the new ones come pre-trimmed. Are they labeled 1-5? If so, I would say move on.
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Postby kevinh » Sun Dec 11, 2016 9:16 pm
lstinthot wrote:Sounds like the new ones come pre-trimmed. Are they labeled 1-5? If so, I would say move on.
yep the new ones come pre trimmed and the gussets are only added on 1-4. 5 just has some holes.
kevinh
Postby samiam » Sun Dec 11, 2016 9:30 pm
Wow I thought my kit was good. These new kits must go together fast!
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby Area 51% » Wed Dec 14, 2016 7:55 am
You would think so........wouldn't you. The pre-notched ribs are a big help, but the holes in both the ribs AND gussets are NOT! Any time savings were cancelled out for me.
Ben, and anyone else that has not bent their gussets yet, go to the Waiex plans topics, and look up W19 woes. The bends are critical in their placement, and there is a grand solution on You Tube.
Postby Concorde » Wed Dec 14, 2016 12:46 pm
51%, My Gussetes were perfect match, and the bents turned out very nice. Sorry about 51% didn't see your name.
Ben
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby Concorde » Fri Dec 16, 2016 10:10 am
Is there any point of making a Gusset for rib 5 ? Or it's just some extra weight with no real benefit .
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby Bryan Cotton » Fri Dec 16, 2016 10:29 am
Ben,
Weight is the enemy. Don't add stuff not called for as a general rule. Ribs are not highly stressed members either.
Users browsing this forum: Google [Bot], wlarson861 and 120 guests
