Klimek wrote:I have noticed the bearing seats on one wheel are not parallel and this alone will cause brake vibration. This is one item you should check and correct if
needed.
jowens wrote:I am not having any luck completely seating the races. I currently have them seated enough that the standard bearings and the dust covers are flush with the side of the wheel but there is still about 1/16" to go for the races to be fully seated on the step in the wheel. I oiled the hub and races with 1 in 3 oil about a week ago and have tried on and off to seat them more. They are seated squarely (whew).
Tonight's attempt was with a 1/2" carriage bolt through a heavy duty 1 1/4" socket through one wheel half, four 2" fender washers on the other side and a tight nut. I put this in the shop vise loosely holding the nut. I then hit it with a 3 pound sledge. That helped seat the races about 1/32" of an inch.
Users browsing this forum: No registered users and 112 guests
