Piano Hinges
Piano Hinges
Postby x3 skier » Thu Nov 17, 2016 9:17 am
Finishing up the Empennage on my Onex Tail Kit.
What's some ways to secure the hinge pin on the elevator and rudder? The Cherokee I fly just bends over the ends of the pin for the hinges but I was wondering of others used a different method.
Thanks
Onex 202, Finishing Fuselage Kit, Controls/Gear/Engine Config kit delivered.
x3 skier
Re: Piano Hinges
Postby onex28 » Thu Nov 17, 2016 9:35 am
The plans call for cotter pins. See ONX-T01, upper left hand corner, Section R-R
onex28
Re: Piano Hinges
Postby x3 skier » Fri Nov 18, 2016 11:22 am
Thanks. I was just wondering if there were other methods that had been used.
Cheers
x3 skier
Re: Piano Hinges
Postby x3 skier » Fri Nov 18, 2016 2:43 pm
BTW, the plans for the tail kit do not come with a ONX-T01 drawing. If you could email the piece with Section R-R, I'd appreciate it.
rick@skibuff.com
Heers
x3 skier
Re: Piano Hinges
Postby peter anson » Sat Nov 19, 2016 2:42 am
Here's the method I used for anchoring all the control surface piano hinge pins on my Sonex:
http://www.ansoneng.com/hinge-pin/ (You'll have to follow the link. Can't get a picture to appear for some reason.)
Make a 90 degree bend at the end of the pin. Cut a small tab from 0.025" Al and form a joggle in it to match the folded end of the pin. Retain it with the next rivet along the spar. They are easy to make, easy to inspect and can be removed by drilling out the retaining rivet - also easy in my view. The one shown in the photo is looking up at the aileron pin.
Sonex 894
287 hours
peter anson
Re: Piano Hinges
Postby wlarson861 » Sat Nov 19, 2016 4:46 am
I used the plan method of drilling a small hole through the last lug of the hinge and putting in a cotter pin. the hinge pin needs to be a little short to do this but it works well. This was done for the ailerons,flaps,rudder and elevator hinge pins. If you are working from the tail kit plans and continue on,the full plans should have the call out for the drill size and correct cotter pin to use. For the trim tab hinge I used the bent end hinge pin secured with safety wire to the trim tab.
Bill Larson
N861SX
wlarson861
Users browsing this forum: Bing [Bot] and 124 guests
