by structurespilot » Sun Aug 12, 2012 9:52 pm
Good Post, it makes us all think, and remember all the things learned back in ground school. I think the downdraft did contribute to the crash. We also don't know how much the terrain rose up to meet him. I've had a scare in the mountains here, due to down drafts. They are not always violent, sometime they just gradually push you down. At that point all you can do is lean the engine for max performance, and start looking for a spot. Lucky for me I didn't have density alt. working against me too.
I've flown C150, 172, and C182 in the mountains, up to 12000' and the only one which felt like it had enough power was the C182, which I never loaded with 4 adults either.
In my multi engine training, we had to show our calculated DA, and required runway length, accelerate to stop distance (for an aborted TO), for each flight. Too bad the guy in the video hadn't taken the time to properly flight plan for the flight, using the temp, distance, and actual weights for the day. Plus the chances that the Stinson was developing the power that it did when the POH was written, are slim to none.
Also in Canada, on your commercial flight test, you fail if you do not pick a spot along the runway, to have developed enough power and rotate. You must also announce to the examiner, your decision as you pass the go no go point.
Thanks again for the post, stay safe everyone.
Norm
Waiex Tail kit built! Working on Corvair engine core.
Norm (structurespilot)
