Dimple skin and countersink connecting thick aluminum angles
Postby dhogue » Sat Nov 12, 2016 6:57 pm
Hello Sonex builders,
I am working on the cockpit side panels of my Onex kit.
I am going to use Flush CCC-4x rivets on the thick vertical angles and the skin.
I will Dimple the Skins.
I will countersink the thick aluminum angles to which the above dimpled skins will be attached.
I am using scrap skin thickness material and scrap thick angle material to practice countersinking the angles so the dimpled skins fit with no gap between the skin and the angle.
I am using the Sonex simple dimple die to Dimple the skins and a 100 degree micro-stop/countersink on the thick angles.
I am having to countersink the angle holes very deep to get the dimpled skin to fully seat to the angle. I am concerned at the depth of the countersink.
I post to ask if you know of a dimple/countersink method that works for this scenario?
(I did do a search but do not see a post that addresses this scenario)
Don
Don Hogue
Onex 0173: Tailwheel: AeroVee Turbo.
Horiz/Vert Stabs, Rudder/Elevators, Fwd/IB/OB/Aileron Bellcranks on Ribs and Main Fwd/Aft Center Wing Spars, Fuselage : Complete.
WIP: Wings
dhogue
Re: Dimple skin and countersink connecting thick aluminum an
Postby rk2436 » Sat Nov 12, 2016 11:07 pm
You want to countersink using a 120 degree cs for pop rivets,regular an rivets are 100 degree.
Bob K
Orig builder kit 1143
Now flying RV-12
Evergreen Park,Il
rk2436
Postby Bryan Cotton » Sun Nov 13, 2016 12:04 am
I agree with Bob. I totally missed that you were using the wrong countersink the first time I read your post.
Postby jowens » Mon Nov 14, 2016 8:28 am
Hi Don,
I had a difficult time finding a source for a 120 degree countersink that goes into a microstop. I have had excellent luck with the yard store for tools.
http://www.yardstore.com/countersinks/1 ... 0-deg.html
I'm not sure how the Onex engine mount is attached to the fuselage, if it is the same as the Sonex you will need a 1/2" 100 degree
The Yard Store is also a good source for reamers.
Jim Owens
Dynon HDX1100, dual controls, Viking 110, taildragger
800 Hours, first flight 10-17-2018
jowens
Postby dhogue » Mon Nov 14, 2016 9:59 am
Thanks guys,
The 120 degree C/S drill bit solved this for me.
Don
Don Hogue
WIP: Wings
dhogue
Users browsing this forum: Google [Bot], wlarson861 and 132 guests
