Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby markschaible » Wed Nov 02, 2016 2:42 pm
Hi Folks,
For those of you who haven't already seen it, we have a video in the EAA Hints For Homebuilders series about removing powder coat from certain areas of our welded parts, and why it's necessary. You can also see the torch method in-action in this video: http://www.eaavideo.org/video.aspx?v=61439759001
You can find many more great technique-based videos like this on the Sonex Video Tips page: http://www.sonexaircraft.com/support/videos.html
and tons more (not all applying directly to Sonex construction) on the EAA Hints for Homebuilders web site.
Regards,
-Mark
Mark Schaible
General Manager
Sonex Aircraft, LLC
phone: 920-231-8297
fax: 920-426-8333
http://www.SonexAircraft.com
http://www.AeroConversions.com
Sales Info: sales@sonexaircraft.com
Orders: orders@sonexaircraft.com
Accounting: accounting@sonexaircraft.com
Tech Support: tech@sonexaircraft.com
Build a Sonex Aircraft in Your School!
Check out the Sonex Education Initiative: http://education.sonexaircraft.com/
markschaible
Postby Bryan Cotton » Sat Nov 05, 2016 9:34 am
Mark,
I should watch more of those videos. It is hard to find the time!
Here was how I opened up my bushings for the mixer mount. There is a tube with a slot in it and a piece of scotch brite taped on like a flag.
The scotch brite gets rolled around the tube and inserted into the bushing. I spun it both forward and backward, i.e. in the unroll direction.
You will notice I modified my -3 rivet cutter tool with a counterbore so I could cut rivets shorter. That was for the nutplates to hold the pitot mount block in the tail.
When I painted my tank cover, as mentioned, the SEM primer didn't stick. By running a straight edge over it I easily knocked off 70% of the paint back to bare aluminum and I took the rest off with acetone. Try 2 was with industrial Rustoleum flat black. That turned out awesome.
My mixer is pilot drilled together and soon to see the tapered reamer.
Postby Bryan Cotton » Sat Nov 05, 2016 1:53 pm
I chucked the painted tank cover back in place while Adam was putting pistons in. Looks cool.
Here I have reamed the mixer for the taper pin. Came out good. I reamed by hand.
Postby Bryan Cotton » Sun Nov 06, 2016 10:57 pm
It was a pain to mask the mixer. But I didn't want to get any black paint on the black powder coat.
Postby Bryan Cotton » Thu Nov 10, 2016 11:52 pm
Mixer is installed.
Idler pushrod is sort of installed. I need some shorter bolts.
Postby Bryan Cotton » Mon Nov 21, 2016 1:34 pm
Whatever you do, Waiex Builders, don't drill the top tube of the mixer for an AN5 bolt before you install it. If you do, you will miss the joy of removing the mixer to open up that tube, and the thrill of getting the washers between the bushing and mixer mount while getting all the holes to align for a second time. Short video:
https://youtu.be/yDC2kAVK5Cg
Postby Bryan Cotton » Mon Nov 21, 2016 8:56 pm
My tap handle was too small so I made a custom one using 1/2" open end wrenches and the good duct tape.
This is for a tail mounted pitot A la Kip.
Postby Bryan Cotton » Tue Nov 29, 2016 9:40 pm
Postby Area 51% » Tue Nov 29, 2016 9:55 pm
What diameter tube did you end up going with?
Area 51%
Postby Bryan Cotton » Tue Nov 29, 2016 11:32 pm
1/4" OD
Return to Photo Album
Users browsing this forum: Google Adsense [Bot] and 25 guests
