Substance in Pitot/Static Lines
Postby bnvoss » Tue Oct 25, 2016 10:34 am
I have been flying my Sonex about 10 years with 485 hours on her and I have recently had accuracy problems with my Airspeed Indicator. Several months ago it started reading about 5 to 10 mph low (from CAS). More recently it started reading up to 40 mph low. :o I discovered the cause was both my pitot and static lines in the wing had some kind of fluid in them. Not water, it looks like some kind of oil based fluid - slightly yellow. Even the outside of the lines had a light film on them.
The plane has always been hangered and no fluids of any kind have ever been near the lines. The lines are yellow Tygon Tubing and I think I purchased them from Aircraft Spruce (11 years ago). Anyone seen this before? Any ideas?
Bob Sonex 550 Jabiru 2200 485 hours
bnvoss
Re: Substance in Pitot/Static Lines
Postby Direct C51 » Tue Oct 25, 2016 11:05 am
Bob, I purchased my kit second hand and it included that same yellow tygon tubing unused in a plastic bag. It was covered in a yellow oil like substance. It was about 8 years since the original owner purchased it. I threw it out and bought new clear tygon.
Direct C51
Postby bnvoss » Wed Oct 26, 2016 10:37 am
Sounds like my problem. Thanks.
Bob
bnvoss
Postby Msing48 » Sun Oct 30, 2016 8:05 am
After flying my Sonex for almost 10 years, I had the same problem with oily fluid in my pitot line. I blew it out and was good for another year, then had to do it again.
Msing48
Postby Sonex-1081 » Mon Oct 31, 2016 8:03 pm
I received the yellow tygon tubing with my Sonex kit purchased in 2007. When I went to install the pitot system in 2014 I had the same oily substance inside & outside my tubing. I think the stuff just degrades and turns to oil so I considered it unusable, threw it away and installed new clear tubing - I was a bit annoyed as the tubing was all neatly plumbed into place through bushings in every wing rib, and the wings were attached and rigged. I had to make a flush connector so I could draw the new lines through the rib bushings - no problems with airspeed/altimeter after new install.
Sonex-1081
Users browsing this forum: No registered users and 135 guests
