Moly lube
Moly lube
Postby Bryan Cotton » Fri Sep 23, 2016 10:52 pm
I see it called out in the assembly manual. Grease, spray, anti-seize, or what is it?
Re: Moly lube
Postby MichaelFarley56 » Fri Sep 23, 2016 11:09 pm
Are you installing the connecting rods onto the crank?
I used this or something very similar: https://www.amazon.com/CRC-SL3331-Extre ... =Moly+lube
It was the same thing but found at the local Advance Auto Parts or Autozone. Look in the area where all the RTV is stocked.
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: Moly lube
Postby kmacht » Sat Sep 24, 2016 7:18 am
Molybdenum grease. It is usually a paste usually used as an antisieze compound. Loctite makes a version in a can with a brush. It is Loctite 51048.
#554
kmacht
Re: Moly lube
Postby grevaly » Sat Sep 24, 2016 10:16 pm
I think the moly grease is used on the bottom of the lifters for the break in of the camshaft. My engine kit came with a small amount in a foil package.
I bought some extra at the parts store to give that area a little extra treatment. I think John liked white lithium for all other bearing assemblies.
Mark Conner
Sonex Std Gear Aerovee #1242
Mostly Plans Built
grevaly
Re: Moly lube
Postby mooneybum » Sun Sep 25, 2016 9:28 pm
Moly lube, when I started home building 46 years ago, we used a mixture of 50 weight oil and STP and
you never heard anybody having any problems.
mooneybum
Re: Moly lube
Postby Darick » Tue Nov 29, 2016 10:25 pm
Molybdenum disulfide...dry film lubricant like graphite, mixed in with grease commonly referred to as moly lube. Parker Hannifin seals used to coat all their hydraulic seals with molybdenum touting it as "better" than the competition. It didn't really make any difference as the powder washed off as soon as the seal was put in a hydraulic system where the seals were totally immersed in hydraulic fluid.
However, when used in grease as in the AreoVee assembly, it will initially add extra lubrication.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Users browsing this forum: Google Adsense [Bot] and 7 guests
