Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sat Sep 17, 2016 11:53 pm
Hinge off- holes in decent shape. The old hinge is trashed from sanding.
I don't care that the old hinge is trashed. Here I have a cheapie aluminum angle from Menards. It has a square inside corner. I butted the hinge into that corner and transferred holes.
Then I popped the hinge off, got a .040" shim, and a new piece of hinge. The holes are transferred from the angle to the new hinge.
Here is before and after. I am going to rivet the hinge back onto the flap with a handful of aluminum rivets tomorrow for a fit check. If it is good I'll drill them back out and rivet it for keeps.
To do things right the first time is easy. To fix a screwup takes true skill.
Postby Bryan Cotton » Sun Sep 18, 2016 11:00 am
No pics- but I did a trial fit. The flap is nicely flush with the top skin and when the flap is bottomed out I have a little overtravel. I'm happy.
Postby Bryan Cotton » Tue Sep 20, 2016 9:47 pm
We did the other flap. Pretty good, but not as perfect as the first. We got the missing travel back.
In prep for storing the wings Thursday, we moved the Waiex to a neighboring hangar.
Postby Bryan Cotton » Thu Sep 22, 2016 10:23 pm
Both wings are stored:
...and we are onto the Aerovee.
New signature:
Postby vwglenn » Fri Sep 23, 2016 8:03 am
OOOOoooooo...fun stuff.
Glenn
Sonex #600
N889AP
vwglenn
Postby Bryan Cotton » Tue Oct 18, 2016 10:18 pm
Adam and I had a visitor tonight - Randy from Area 51.
Postby Bryan Cotton » Sun Oct 30, 2016 9:41 pm
Adam was watching some ballgame on TV. I snuck over and put in nutplates for my tail mounted pitot tube.
Postby Bryan Cotton » Tue Nov 01, 2016 11:39 pm
Adam was watching some ballgame so I put the engine aside and worked other stuff. Here I have painted the top longerons and the mickey mouse ears.
Here I've painted the tank cover. Later I noticed most of it had peeled off. Odd, I prepped this part the same as the others and they were fine. I have been having inconsistent results with the black SEM self etching primer.
I tried the torch trick to remove the powder coat from the mixer. I don't think I cooked it enough as it didn't fall off as others report. Ended up using a scotch brite wheel on an angle sander.
Postby ihab » Wed Nov 02, 2016 12:20 am
Bryan Cotton wrote:I tried the torch trick to remove the powder coat from the mixer. ...
Hmmm ... why do you have to remove powder coat in the first place?
Ihab
Ihab Awad, San Jose, CA
ihab
Postby Bryan Cotton » Wed Nov 02, 2016 8:04 am
Ihab,
Parts of that mixer weldment ride on a bronze bushing. The bushing won't go on over the powder coat. In fact, after removing the powder coat I still have to open up the bushing a little.
Return to Photo Album
Users browsing this forum: No registered users and 38 guests
