Flush rivet option poll
Are you using flush rivets on all exterior skins?
Yes, I used flush rivets on all exterior skins
3
23%
No, I used protuding head rivets on all exterior skins
10
77%
Total votes : 13
Re: Flush rivet option poll
Postby 142YX » Wed Jul 11, 2012 4:34 am
Thanks for the response guys, i do appreciate it.
I forgot to lower my air compressor pressure when i did my leading edge, and this probably contributed to the failure rate.. but i can honestly say that i have tried just what you have both described in the past as still experienced a high failure rate. Using Sonex's simple dimple die, i found that the hole was way to big if i used a #30 before dimpling. I ended up using a #32 simply because it was the smallest hole i could make and still jam a cleco into, and fit the simple dimple die nail through, and i was still really disappointed in how large the holes came out post dimpling (50% of clecos will just pop out of the final hole). I think when i do my other leading edge, i may try to find a smaller nail (which will probably surely break on me) or make some kind of custom nail so that i can dimple through a #40 hole and then upsize and painstakingly de-burr post dimple. These CCC-4# rivets really have been the biggest annoyance to me overall from this entire build.
450 hours and counting..
142YX
Postby rizzz » Wed Jul 11, 2012 4:43 am
There is a good article on this subject on the sonexaus website:
http://sonexaus.wikispaces.com/Dimpling
It adresses the issue of nail sizes and provides tricks for how to still make the cleco's usable
Users browsing this forum: No registered users and 62 guests
