Build Order Baffle vs. Cowl
Postby OneTallShort » Mon Sep 05, 2016 7:20 pm
I've got the laser-cut baffle kit. On your Sonex, did you put the engine baffles on first, or fit the Cowl? Any thoughts on which order is easier?
Gregg Short
Sonex N715SX
OneTallShort
Re: Build Order Baffle vs. Cowl
Postby MichaelFarley56 » Mon Sep 05, 2016 7:54 pm
Hi Gregg,
You basically have to fit the cowling first and then trim the baffle as needed to ensure a good tight seal between the baffles and the cowling. Unless you have the cowling there to measure, you won't know where to trim the laser cut baffle parts.
Best of luck and take your time. The cowling and baffle fitting is a tedious process but if you take your time and trim a little at a time, it will work out fine!!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Users browsing this forum: Google [Bot] and 37 guests
