Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Tue Aug 30, 2016 9:57 pm
Here is how I trimmed my bushings:
I could not find the callout for bolting the aileron pushrod to the bellcrank. I assume the bolted joint is the same as the pushrod to the ruddervators. Can anybody steer me to the right page?
Postby lstinthot » Wed Aug 31, 2016 5:20 am
Bryan Cotton wrote:I could not find the callout for bolting the aileron pushrod to the bellcrank. I assume the bolted joint is the same as the pushrod to the ruddervators. Can anybody steer me to the right page?
The bolting is on page SNX-W02. Looks like you build the push rod in "C" and it directs you to "W". I kept looking over C02 then went back and saw I miss read the plans.
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Postby Bryan Cotton » Wed Aug 31, 2016 8:01 am
Thanks Mike!
Postby Bryan Cotton » Fri Sep 02, 2016 5:20 pm
We are putting in the controls.
Postby Bryan Cotton » Sun Sep 04, 2016 10:32 pm
Adam bolting up one aileron:
And the other:
Wings back on:
And the video:
https://youtu.be/D1p1zbcOnwY
The bad noise was because we have no aft stop yet. The pushrod dragged on the rib hole.
Postby Bryan Cotton » Mon Sep 05, 2016 6:36 pm
To lock my sticks in the neutral position I used a piece of scrap with a 3/8" hole. Put it on the roll stop and clamped it.
Here is what I used for an aft stop. A piece of scrap clamped to the floor structure.
Finally here is my rigging setup per detail N, C03.
Ailerons are rigged minus socking down and cotter pinning everything.
Postby ScottM-Sonex1629 » Mon Sep 05, 2016 7:05 pm
Nice progress! Are you planning to leave the wings attached now that they are rigged?
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Mon Sep 05, 2016 7:28 pm
Nope! Not enough room. Wings go on the shelf and motor comes next.
Postby vwglenn » Wed Sep 07, 2016 12:16 pm
You're going to go blind flying that thing.
Glenn
Sonex #600
N889AP
vwglenn
Postby Bryan Cotton » Tue Sep 13, 2016 10:06 pm
To move my flaps down, I need to remove and replace the hinges. Sadly, they are hard to drill out. I can't knock out the mandrels as the structure is too springy, and the rivets tend to spin if you just go at it with a drill. So, I am sanding the heads off.
While I was in the middle of that fun, Adam made a second set of wing racks.
I plan to fix the flaps before we store the wings. Then it is onto the Aerovee!
Return to Photo Album
