radfordc wrote:I bought a Sonex that had loose wing bolt holes....enough that I could move the wing tip up and down about an 1". I fixed the problem by increasing the size of the hole from 3/8" to 7/16". I updrilled the holes using a hand drill and lots of WD-40 lube. I did the drilling in 1/64" increments....25/64; 13/32; 27/64. For the final 7/16" hole I used a reamer instead of a drill bit. The result was a nice tight fitting hole that required tapping the bolts home with a light mallet.
Users browsing this forum: Bing [Bot] and 103 guests
