by Direct C51 » Tue Aug 16, 2016 8:29 pm
I have an older kit which came with 3/4" x .125" aluminum bar to make the fuel tank straps. I made them to plans 17 7/8" from bend to bend for the aft straps and 17 5/16" for the forward. I bent them pretty close to the contour of the fuel tank, but they seem to be more than half an inch long each. When clecoed to the longerons, the straps touch at the ends and have to be bent to put the bolt through. When the fuel tank is set in, the straps hang a good bit lower than the tank but the ends are touching. I have the yellow colored plastic tank. Do the strap lengths seem correct? Does the flat portion on the forward lower part of the tank sit flush on the cross tie? The plans make it look like the sides of the tank at the widest point, where the angled top sides meet the curved bottom, is about flush with the longerons. For my straps to work, the sides of the tank would have to be about an inch lower than the longerons. Any ideas?
