lstinthot wrote:We did significantly more cleaco's. Started out in every other hole and put the bucking bar between the cleaco's. We used a bucking bar that is about 1 inch wide for most of the rivets on the first spar. Worked with the wife on some of the rivets and we used the Sonex bucking bar, a bit heavier than our 1" wide one. It worked fine as well. Could not have as many cleaco's in using the Sonex bucking bar. I like more cleacos over less. As long as the bucking bar can fit.
I did not have an issue having the bucking bar over more than one rivet at a time. It was never over two rivets that where not set yet. Only one new rivet at a time under the bucking bar.
Sometimes we had to get creative, use another rivet gun with the shop head rivet tool on it, then back rivet the rivet due to not being able to get any bucking bar in the area.
We used rivets for the optional AN3 bolt area. Could not see any benefit to using bolts. If the rivets are strong enough, I do not see myself taking the part off or wanting to check the bolts during inspections.
lstinthot wrote:I would check with your local EAA chapter to see if they have a rivet squeezer. One here did, it just happen to be not working when we were ready to rivet. It will take a pretty good size squeezer to do the *5 rivets. I did some of the rivets by myself, can be done just not as nice a finish compared to the ones I had help with. We did use the technique to move around the spar, not on purpose, it just worked out that way. With every other rivet hole, I have very little banana effect. We did have a few counter sunk rivet holes that I chased with a drill bit. Did not have to actually turn the drill bit with the drill, just work it through the hole was all that was needed. An RV builder showed me that. You will need some kind of other bucking bar to get under the upper stiffener angle W11-08 and the spar cap. Might be a scratch building thing, but my gap between the spar cap and the stiffener is to tight for a rivet tool to fit in there and I had to come up with a piece of metal about 1/2" thick an inch or two wide to act as a bucking bar.
Mike
Users browsing this forum: No registered users and 77 guests
