Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Tue Jul 19, 2016 10:29 pm
It has been a very unproductive month. Started with the end of summer camp. Adam and I did one shift in the hangar then came down with colds. Next off to Connecticut for my niece's wedding. Tonight we did two hours and worked the rear spar carrythrough.
The long 3/32" cleco above the gnu-vise is a pilot hole for the mounting bolt. Next week Adam is off to the boundary waters and I hope to spend some time at Oshkosh.
Overall the wing rigging process has not been bad.
Postby Bryan Cotton » Thu Jul 21, 2016 11:11 pm
Adam and I made some real progress and I only bled a little. Here is the left hand drill bushing in place:
Adam drilling. He did the right side and I did the left.
A short video:
https://youtu.be/6wGUBuIGPXI
Drill bit through:
The other side is pinned with an AN4 bolt through the angle into the drill bushing.
Now I need to take the wings out and upsize that hole. This method seems simple and foolproofish.
Postby Bryan Cotton » Sun Jul 31, 2016 8:32 pm
Here is my right hand landing light:
I was convinced I needed to nutplate the wingtips as the lens is impossible to screw down without access. I talked to Bob Carson and he says both his lights are aimed 20' ahead when taxiing. I think I will do that, then use aluminum pops to attach before flight.
Adam and I pulled the wings today. I am making the tooling to updrill the holes. Pictures later.
Postby vwglenn » Mon Aug 01, 2016 8:54 pm
I have $10 riding on ya!
Glenn
Sonex #600
N889AP
vwglenn
Postby Bryan Cotton » Mon Aug 01, 2016 9:48 pm
I know Glenn - I've tried to kick it up a notch since I got back!
Postby ScottM-Sonex1629 » Mon Aug 01, 2016 10:34 pm
Come on Bryan! You got your kit a only few months after me, I've already got 8 hours of Phase 1 time logged!!! I'm nowhere near your post count on this forum...get building, post when your done!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Tue Aug 02, 2016 7:09 am
Scott,
You are too kind - you forgot to mention the big break you took to help me catch up! Also that is the same thing John Monnett said to me Thursday.
Postby n982sx » Tue Aug 02, 2016 10:25 am
Definitely a relationship between too much posting and not enough building. Sonex 982SX took four years to build along with a lot of posted build logs.
The new airplane has far fewer build logs and is zooming along in comparison.
Don't stop posting though, we all like them too much.
Bob Meyers
n982sx
Postby ScottM-Sonex1629 » Tue Aug 02, 2016 2:51 pm
Bryan,
I have a solution, build at home with your sons...
Post at work like everyone else does -- LOL
Scott Meyer
ScottM-Sonex1629
Postby Bryan Cotton » Tue Aug 02, 2016 11:12 pm
Here is my tooling. The thick piece guides the drill on entry. The hole is bored to 1/4" all the way through, then 5/16" down to within about 1/8" from the bottom of the hole. The little piece is for the drill exit.
Here the tool is clamped in place. I put a 1/4" rod to align the pilot hole in the fuselage with the tooling.
Here is the back side.
The 5/16" bit slides into the entry tooling for nearly an inch before any drilling takes place.
Of course I drilled the tooling holes on the drill press. Adam worked the aft spar mount while I did this - a bunch of updrilling and deburring.
Return to Photo Album
