by fastj22 » Fri May 25, 2012 10:49 am
This installation is the new one with the VW adapter plate on the VW Sonex mount. When I did my measurements, it was based on the Jabiru mount and no adapter plate and interfered with the fuel tray. From the picture, it looks like the engine is pushed forward quite a bit, hence why it now clears the fuel tray. Plus The Jabiru mount is much closer to the firewall than the VW one.
So now you have an engine pushing close to 200lbs being hung quite a ways forward on the aircraft than the Jab3300. Weight and balance will be interesting.
Jan has not published W/B on the RV12 or for any other aircraft that I'm aware of.
