Bryan Cotton wrote:How does Steve's tank mount? Hard to tell what holds it in from the pictures.
WaiexN143NM wrote: When my father and i get into our waiex together thats 400 lbs in the seat. As fuel burns out of the main tank the cg moves aft and pitch get pretty light. .
fastj22 wrote: And if you have trouble transferring the fuel, you may be really aft CG on landing.
peter anson wrote:Hi Steve,
Do you run off the auxiliary tank until fuel is low and then switch over to the main tank? Do you have a fuel level sender in the aux tank? Your arrangement of pumping straight from the aux tank is attractive because it is so simple, but I had imagined running off the main tank first and then replenishing the main tank from the aux using a separate pump.
Sonex 894
