by LarryEWaiex121 » Fri Jun 03, 2016 4:03 pm
Phil,
I did something similar on Waiex 121YX. I built as close as I could using the plan instruction. Not good enough. Used up my right side tire in just over 80 hrs.
Took matters into my own hands and while I had the tires off the wheels; I used two long carpet layers straight edges(12 feet long), against the bare wheels. Extended the center line forward about the 12 foot and used the straight edges to put the .7 degree or whatever you say the plan called for.
I did this so long ago I've forgotten the exact number but it ended up being toed in about 1" each side, at the end of the 12' straight edge. In the end it was perfect. Now my tires go over 150 hrs. I do corner too hard and taxi too fast.
The tires are basically junk tires to begin with and they're being used well beyond their intended range I feel. I have to say though, I've never had a flat or slid one on the bead and ripped off a valve stem. I keep mine pumped to 50psi.
Larry
Waiex 121YX, Camit 3300
These planes are not optimized for long taxi runs. That's is probably the hardest thing on these tires. Especially if one is at full weight and the weather is hot hot.
