Aileron bellcrank - tips?
Re: Aileron bellcrank - tips?
Postby samiam » Mon May 23, 2016 3:51 pm
Thanks guys. That picture helps a ton.
I'm wondering if either my 5/16" bit is not accurate enough or my steel bushings are slightly oversized though. When I line drilled the bushing, the steel piece still did not fit in.
I'll mess around with it in the shop tonight and see what I can come up with.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby kevinh » Mon May 23, 2016 8:04 pm
The steel bushings are a little big, you'll need to run the assembly up and down that 5/16" bit until enough bronze is removed (I actually just held the part in the vice and moved the vice around on the bit until the steel bushings worked nicely.
kevinh
Postby samiam » Tue May 24, 2016 2:11 pm
kevinh wrote:The steel bushings are a little big, you'll need to run the assembly up and down that 5/16" bit until enough bronze is removed (I actually just held the part in the vice and moved the vice around on the bit until the steel bushings worked nicely.
That's it. Got it. It will take some tweaking/shimming to get the cranks to rotate freely, but this was the key.
This was probably obvious to more experience builders, and took me way too long to get done, but thanks anyhow to everyone for the help!
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Users browsing this forum: No registered users and 66 guests
