kevinh wrote:The steel bushings are a little big, you'll need to run the assembly up and down that 5/16" bit until enough bronze is removed (I actually just held the part in the vice and moved the vice around on the bit until the steel bushings worked nicely.
Users browsing this forum: Google [Bot] and 70 guests
