achesos wrote:Robbie,
After reading the string I'm convinced that you are reading fuel level by using a pressure sensor that can't read level - only pressure. This device can of course be calibrated to display in gallons, but only due to the change in pressure on the face of the probe caused by the additional mass of the fuel (increased pressure). Works great until you add ram air into the cowl in flight (likely being driven to (slightly more) positive pressure, which then short circuits into your tank volume. In my opinion, the only solution is to add a second sensor in the tank that can read the pressure above the liquid level of the fuel. You then need to wire these together such that the combined electrical output is what is used to calibrate your display - this difference will be the change in fuel level, independent of airspeed or altitude... make sense?
sonex1374 wrote:Here's my $30 system using a backup camera I got off ebay,
https://www.youtube.com/watch?v=pnXE_hS ... &index=144
Jeff
