Does the pick up tube fit down inside the filter???? Should the pick up tube slide inside?
Rynoth wrote:I concur that Chris' installation fits what I did per the Aerovee 2.1 installation manual and his quote of the manual. Page 40 of this document: http://www.aeroconversions.com/support/ ... Manual.pdf
I agree Chris, that the fitment of the pickup seal seemed questionable at best. Just getting the mini-sump pressed deep enough to engage the nuts on the threads took a lot of pressure, and the seal seemed to fit pretty cockeyed. The bottom diameter of the seal doesn't match the recess in the filter. If I recall, I replaced the studs in the case with longer studs in the sump hardware kit (this is not called for in the plans) just to make it easier to get the nuts on.
I haven't yet changed my oil for the first time. When I do so I imagine I'll initially drain the sump oil from the oil return line from my oil separator (or the plug that would otherwise connect to this line) before removing the mini-sump. Still probably a messy process.
pfhoeycfi wrote:Did you end up modifying your upper seal to make the fit better? My upper seal sits on the pickup tube so crooked & loose you would think its not made for this purpose...and there is no way its going to sit flat or flush on the filter...the seal just doesn't appear that it was made to go with the filter...very odd.
