by Bryan Cotton » Sun Mar 13, 2016 1:48 pm
My left wing is stored:
The shelf capacity should hold the wing, but I am a belt and suspenders kind of guy. The racks are screwed to the wall and a heavy duty shelf bracket is underneath. The racks are designed so you insert the trailing edge first, lift them high, and drop them into the notch on the bottom for the leading edge. If a gust of wind comes from behind, it will rotate out on the nose but then will hit the top of the bracket.
Next!
