corrosion protection - building a Waiex
Postby 1labelloj » Fri Mar 11, 2016 12:46 pm
I have decided I would like to apply some corrosion protection in places where two parts overlap. I do plan to finish the outside as polished aluminum so I do not want to use a product that will seep through to the outside skin.
I was wondering what builders are using. Can I use a product from a local hardware store like one of the Rustoleum primers? Is there a specific product ingrediance I should look for?
1labelloj
Re: corrosion protection - building a Waiex
Postby Bryan Cotton » Fri Mar 11, 2016 1:54 pm
I use SEM self-etching primer. I know others that have used different brands of self etching primer they bought from NAPA auto parts. I don't think I would use rustoleum as it is oil based and softer. The SEM dries thin, hard, and is durable.
Postby samiam » Fri Mar 11, 2016 9:27 pm
Uh oh, here it comes!
All kidding aside, chances are that you will be getting a lot of biased opinions about what to use, not exactly scientific evidence of the best thing to use.
Since nothing is required, do whatever helps you sleep best at night.
Mike L
Sonex #1345
Tail complete
Working on wings
samiam
Postby Bryan Cotton » Fri Mar 11, 2016 9:41 pm
True, I mostly use nothing. I made a few parts from 7075-T6 and those are primed.
Postby WaiexN143NM » Mon Mar 14, 2016 10:58 am
Hi all,
When building our waiex, we primed everything with duplicolor self etch primer (green) from kragen / O'Rielly auto parts. Really flows well no runs , dries fast and really sticks. Wiped everything down with acetone prior.
WaiexN143NM
WaiexN143NM
Return to Finish methods
