by Darick » Sat Mar 05, 2016 12:19 am
I'm installing the oops fitting before I install my tank...what a pain! Trying to remove the high ridge inside the tank by just using an exacto knife is ...well let's just say it is an unsatisfactory method. To get a flat surface on the inside for the O-ring to seat on, can only be accomplished by inserting a tool like a dremel tool, with a cut off tool being used.
This is the cutting tool I used. I haven't done any leak tests yet so I don't know how successful it will be.
The scrap piece of aluminum is just keep the Dremel tool at the correct depth.
The diameter of the cutting tool is small enough to insert into the hole but I don't know if the flat area it has cut off, will be a big enough diameter for the fitting. I'm unhappy with this procedure since you really can't see the end result and the only way to confirm a tight seal is of course is to do a leak test.
This view is looking into the largest hole to one of the smaller holes which I just finished cutting the flange. You can't really see what's happening and is a lot of trial and error cutting. Quite an unsatisfactory way of making a leak proof job.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
