Jabiru Alternator Mod
Postby 142YX » Fri Mar 30, 2012 1:39 pm
Dont know if this would fit in the Sonex airframe, but interesting none the less..
450 hours and counting..
142YX
Re: Jabiru Alternator Mod
Postby Andy Walker » Sat Mar 31, 2012 3:12 pm
Wow, neat!
Andy Walker
Postby sonex892 » Sat Mar 31, 2012 5:44 pm
I doubt it would fit a 3300 sonex
Steve
sonex 892 3300 TD 92 hrs
sonex892
Postby hickej » Wed Aug 27, 2014 12:48 am
Has anyone done the stator modification from Jabiru "Procedure For Upgrading 12 Pole Alternator AVDALSR087-2 20th September 2012". They say it starts charging at 900 RPM instead of 1800 with this mod.
Jim
hickej
Postby Bryan Cotton » Wed Aug 27, 2014 7:29 am
Jim,
Is that mod posted in the public domain? I don't have a Jabiru but I do work at a company that makes aircraft generators!
Postby snx590 » Wed Aug 27, 2014 8:44 am
Hi Jim, it says (I assume using same voltage reg) it will put out 12V at 900rpm...not quite enough for charging I think.
It doesn't say how much load current it would support at that speed, so I'm wondering if it would be worth the effort.
My trusty Odessey is going on about 6 years now and has not failed me yet, hot or cold (oil heater used), but I also have not spent extensive time taxiing around with everything powered up.
Did you have any damage from the quake?
Terry
Sonex #590, J3300, C-FTPH
snx590
Postby andrewp » Wed Aug 27, 2014 8:50 am
I dug it up here:
http://www.avcom.co.za/phpBB3/download/ ... 54205ceb11
But I assume it is on their web site somewhere. I had missed this.
Bascially take the existing alternator and move it from two parallel windings to a single continous one. Higher voltage, less current, but they don't mention anything about it. It certainly is simple enough to consider doing. I have an LED on the panel from the regulator showing when it isn't supplying voltage and while it hasn't impacted me, it annoys me ;-)
AP
#618
andrewp
Postby fastj22 » Wed Aug 27, 2014 9:47 am
I don't see a real need to do this mod. The Odyssey battery in my plane can handle the electrical load on my plane while taxiing fine. The Aerovoltz LiPo battery I originally had it really could handle the load. Unfortunately I killed that battery.
Postby hickej » Wed Aug 27, 2014 10:38 am
Thanks everyone (FYI no earthquake effects in southern California). So, twice the voltage and half the current is what I'm hearing. Not sure if that would make night time touch and goes charge the battery any better.
Jim
hickej
Postby tonyr » Wed Aug 27, 2014 6:39 pm
Hey Andrew, how fortuitous... I found it about a week ago. http://www.jabiru.net.au/images/AVDALSR ... or_Mod.pdf
Cheers
Richo
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Return to Jabiru
