Powerburst Strobes
Powerburst Strobes
Postby Friesen5 » Mon Feb 22, 2016 9:34 am
I've got limited panel space left for switches. I was thinking of installing a single switch to power both the Aveo Powerburst strobe and position lights.
Does someone have knowledge or experience in doing this? Is it doable?
Mervin Friesen
Sonex 122
Jab 2200
Friesen5
Re: Powerburst Strobes
Postby fastj22 » Mon Feb 22, 2016 9:46 am
Wire them to your master. That way when you forget to turn it off, you will immediately know.
Postby Bryan Cotton » Mon Feb 22, 2016 10:23 am
It is doable. The only issue is you can't turn off your strobes separately. Not good for night IMC. That may not be an issue! I have had to do just that in the Arrow though. The strobes are blinding in the snow at night.
Postby SonexN76ET » Tue Feb 23, 2016 9:18 am
If you plan on using your plane after sunset, check the FARs. I believe they state you have to have your landing lights, anti-collision lights, and navigation lights on separate circuits.
Sarasota, Florida
SonexN76ET
Postby avee8r » Tue Feb 23, 2016 11:16 pm
Hi Mervin
Yes, I did it on my AeroVee powered Sonex. I used a 3 position switch. Center position is off, down is nav lights only, and up is nav and strobe lights. No problem.
I split the nav power wire and connected it to both the upper and lower lugs of the switch. The strobe is connected to only one lug.
You can see a picture of my panel on the Sonex Foundation Panels page.
Happy Landings
John Maxfield
N50NX
avee8r
Postby wlarson861 » Wed Feb 24, 2016 12:41 am
Here is an excerpt from Aeroelectric on how I wired mine. On mine the bottom position is off, middle is nav. only and top position is nav. and strobes.
http://www.aeroelectric.com/articles/Switch_Ratings.pdf
Bill Larson
N861SX
wlarson861
Return to Electrical System
