oil cooler question
oil cooler question
Postby Johns » Sun Feb 21, 2016 4:03 pm
Hi everyone, I need to change the oil cooler on the Aerovee. I did not put the original one on, so is there a recommended one or do I just go to the parts store?
John
Johns
Re: oil cooler question
Postby gammaxy » Sun Feb 21, 2016 4:09 pm
Is there anything wrong with the current one? Just curious.
If you haven't already, download a copy of the Aerovee manual:
http://www.aeroconversions.com/support/ ... Manual.pdf
The manual specifies:
Bottom mount:
Oil Cooler (Jeg's P/N 130-70265)
Top mount:
Oil Cooler for 1971 or later T1 or T2 VW engine (such as CB Performance part number 1727)
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
oil cooler question
Postby Sonex1517 » Sun Feb 21, 2016 4:47 pm
If you need a bottom mount oil cooler drop me a PM. I have one in the box, never opened.
Chicagoland
N1517S
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Johns » Sun Feb 21, 2016 7:45 pm
Chris I discovered a leak in the current one.
Robbie, PM sent.
John
Johns
Postby kevinh » Wed Dec 07, 2016 12:17 am
Hi ya'll,
I'll be working on this in the next few months (woot!). Is the sonex recommendation of "CB Performance part number 1727" what pretty much everyone is using for the top oil cooler? I assume yes, but before firing off an order I thought I'd check.
kevinh
Postby wlarson861 » Wed Dec 07, 2016 1:11 am
That's the one I used. Cools as well or better than the bottom mount I had before.
Bill Larson
N861SX
wlarson861
Postby Bryan Cotton » Wed Dec 07, 2016 8:03 am
Kevin,
That is what we bolted on last Thursday.
Postby kevinh » Wed Dec 07, 2016 11:29 am
thanks!
kevinh
Postby vwglenn » Wed Dec 07, 2016 2:17 pm
It's been my experience that the seals will leak before the oil cooler does on the cars. Get good German (OE quality) seals.
Glenn
Sonex #600
N889AP
vwglenn
Postby sonexsteve » Wed Dec 07, 2016 3:31 pm
To expand a little on mounting the top mount oil cooler.....the little rubber seals I received with my AeroVee kit are quite thick, with an approx. 1/8" wider middle 'ring' around the circumference. I've yet to try bolting down the cooler with these seals but it looks like they would make the cooler body sit proud of the cooler adaptor plate? Have I missed something here, or is that how they should be?
Thanks in anticipation
Steve Moody
Leamington Spa, England.
Sonex #1383, AeroVee #0847.
sonexsteve
Users browsing this forum: Google Adsense [Bot] and 46 guests
