Sonex B models
Sonex B models
Postby ihab » Thu Feb 18, 2016 2:22 pm
Ihab Awad, San Jose, CA
ihab
Re: Sonex B models
Postby Sonex1517 » Thu Feb 18, 2016 2:31 pm
Now that the cat has escaped the bag, I would point out the following in the announcement that is relevant to current discussions:
Sonex Aircraft is expanding engine options with the Sonex and Waiex B-Models, offering the same great firewall-forward support for AeroVee/AeroVee Turbo and Jabiru/CAMit 3300 engines, while adding engine mount options for UL Power 350i, 350is, and Rotax 912-series engines. A new universal cowl is designed to fit all 4 options.
Re: Sonex B models
Postby kmacht » Thu Feb 18, 2016 2:46 pm
Would be interested to see the performance specs for the new model. Looks to be a wider and heavier version of the sonex. The standard aerovee is marginal at gross weight with the current model. Unless they have some trick up their sleeve I'm not sure a standard aerovee is going to do very well in the new model. That's too bad because an inexpensive engine option is what drove me to the sonex in the first place.
Re: Sonex B models
Postby ihab » Thu Feb 18, 2016 2:49 pm
My first question at this point would be, at what weight are these aircraft approved for aerobatics? The original Sonex/Waiex are aerobatic mostly when solo. Can one expect these to be aerobatic when dual? If so, that would be the item that sets them off from their competition (Rans S-19, Van's RV-12, Zenith 650, ...) -- apart from the expected Sonex simple and quick construction, and the reasonable kit cost.
Ihab
ihab
Re: Sonex B models
Postby Bryan Cotton » Thu Feb 18, 2016 2:51 pm
Wow! Big change!
Re: Sonex B models
Postby Sonex1517 » Thu Feb 18, 2016 2:56 pm
The official announcement is now up at http://www.sonexaircraft.com/
Links are also at http://sonexfoundation.com/
I also saw a note about heated seats as an option...!!!
Re: Sonex B models
Postby ihab » Thu Feb 18, 2016 3:03 pm
Sonex1517 wrote:The official announcement is now up at http://www.sonexaircraft.com/
Great, thanks!
First question: Why did Sonex not up the gross weight all the way to the LSA maximum 1320#? I guess my answer to myself would be: to maintain compatibility with the Aerovee. The Aerovee is Sonex's main tool for building a super low-cost aircraft.
That said, though, and perhaps as a result, the aerobatic gross weight allows only 330# of useful load, so with any reasonable occupants, it is still solo when aerobatic.
Ihab
ihab
Re: Sonex B models
Postby kevinh » Thu Feb 18, 2016 4:07 pm
Looks cool. I'm bummed I can't swap my unstarted fuse for the B fuse, but I understand. ;-)
kevinh
Re: Sonex B models
Postby N111YX » Thu Feb 18, 2016 4:58 pm
I was hoping for Continental O-200 capability and a all up weight of 1300 lbs... :(
However, it's good to see some R&D come to fruition!
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: Sonex B models
Postby Bryan Cotton » Thu Feb 18, 2016 5:21 pm
N111YX wrote:I was hoping for Continental O-200 capability and a all up weight of 1300 lbs... :(
That would be the C model!
Users browsing this forum: No registered users and 98 guests
