gammaxy wrote:Great report.
At first glance, your performance seems to be similar to mine. Probably a touch faster in cruise and climb which is expected with your larger engine. Where you say 120knots at 3100rpm, I need ~3150rpm with my 54x46 propeller which is WOT for me.
Is the 152knots you list for WOT a typo? I wrote up a long response in amazement of your truly awesome speed, hoping I'll be able to replicate it when I realized it was more likely to be a typo. Oh well... I can still dream :-)
rizzz wrote:Edit: I'll reconfirm the 152 as I realize it is quite high, perhaps I misread the IAS?
gammaxy wrote:rizzz wrote:Edit: I'll reconfirm the 152 as I realize it is quite high, perhaps I misread the IAS?
Since the power required in cruise flight approximately increases with velocity cubed, I was using the rule of thumb:
Power Required Ratio=(Velocity Ratio)^3
I used 120knots as my max speed, so the velocity ratio is 152/120=1.26
Power Ratio = 1.26^3 = 2.03
I don't think you have twice the power available at WOT (or that I have THAT might extra drag).
I believe I'm probably leaving a few knots on the table due to slightly too course of a propeller (according to Sonex's dyno sheet), so if we assume our drag is about the same and assume I should be able to go a little faster, then I estimate your max speed should be about:
123 knots * (2400cc/2180cc)^(1/3) = 127 knots.
I noticed that your accelerated stalls were all at the same airspeed. Were these level turns? Were you pulling 2G's in the 60 degree turn? If so, I'd expect the airspeed of the stall to be ~36knots*1.41=~51knots. Your video showed how the static port on the wing leads to altitude errors while maneuvering. It seems like your data might be showing the same effect for airspeed.
It does make me curious about your Vx calculations, since a static error at slow speeds would probably make your true airspeed calculation incorrect, and yield too steep of an estimated flight path angle.
Anyway, thanks for sharing the report. It's really well done. Certainly better than what I did. Only reason I'm nitpicking is you have presented so much interesting data so conveniently.
rizzz wrote:gammaxy wrote:rizzz wrote:Edit: I'll reconfirm the 152 as I realize it is quite high, perhaps I misread the IAS?
Thanks for the detailed analysis Chris,
As mentioned before I will need to re-confirm the number as I realize it is quite high.
However I can assure you it is more than 127KT, If you look at the detailed flight reports in my document you'll see that I only did the WOT tests once or twice, however, I have pushed well beyond that 127KT number on a few occasions.
Anyway, I'll make sure I've got the GoPro running when I do the test again, I'll put it on YouTube.
gammaxy wrote:Great video. You've definitely got a fast VW-powered Sonex.
I picked out some landmarks and calculated your average speed over 0.98 NM (once you had accelerated). It took you 28 seconds (+/- 1) for an average groundspeed of 126 knots (+/- 4).
Your airspeed calibration table shows your ASI reads about 10.5% high at 125 knots, so at 145 knots, your calibrated airspeed would be 131 knots. This seems consistent with the ground speed in the video (and the peak speed should be higher than the average over those 28 seconds), especially since I have no idea what the winds were :-)
I flew in a sport air race behind a Jabiru 3300 Sonex who only beat me by 10mph. I think his carburetor was not tuned very well, or he might not have been pushing it that hard. You might be able to beat him :-)
Users browsing this forum: Bing [Bot] and 23 guests
