wing Bolts
Re: wing Bolts
Postby Rynoth » Sun Jan 31, 2016 8:58 am
mike.smith wrote:But interestingly those Sonex instructions never explicitly say to start with the right wing.
From the instructions: http://www.sonexaircraft.com/documents/ ... nstall.pdf
Step 3: Slide the RIGHT wing partially into the fuselage.
Step 5: Insert spar pins halfway into the right spar.
Step 6: Slide LEFT wing partially into spar tunnel.
Re: wing Bolts
Postby mike.smith » Sun Jan 31, 2016 5:14 pm
You're right, you're right, you're right. :-) All I was trying to convey was that MANY of us have erroneously started with the left wing because we see instructions like these as interchangeable between left and right without a preamble that says: "You must start with the right wing." Instead it's just matter-of-factly stated in Step 3. And I never found putting the pins in to be a problem.It was always that the left and right wings would not seat against the fuselage unless you started with the right wing. As always, RTFI :-)
Re: wing Bolts
Postby rizzz » Sun Jan 31, 2016 7:09 pm
SonexEZ wrote:yes that dose look good , i wish the bag was turned over so i would have the correct numbers LOL
Part number for these was: 98497A595
Can be found here:
http://www.mcmaster.com/#catalog/122/3386/=10xczjq
(Although I would buy the cotter pin version which is 98412A211, I had to buy some cotter pins and large washers separately, the locking rings don't fit in that spot).
Re: wing Bolts
Postby Dareha » Sat Feb 20, 2016 12:20 am
How does Sonex feel about using the McMaster tapered pins? Looks like they would be great.
Darrell
Dareha
Re: wing Bolts
Postby rizzz » Sat Feb 20, 2016 1:26 am
The response I got from Kerry was positive, he said his plane had hitch pins as well.
However, for something as important as this I would advise you to contact tech support yourself.
Users browsing this forum: No registered users and 93 guests
