jjbardell wrote:I am weeks away from my first flight so I can only speak of installation and customer service. Matt at MGL has been great and friendly. When I have any questions, he responds very quickly.
As for the install, it was incredibly easy. I purchased the lite, Sandia remote transponder and v6 radio. Add to that the air temp probe, cht, egt, oil temp, oil pressure and the most important part...his wire harness kit. It was a plug and play with minimal soldering needed. His harness kit has three audio inputs (efis, aux in for music and a third I have my iPad w garmin pilot on). This gives me audio alerts to weather and traffic. The v6 can lower or mute all background music when an alert from the efis or traffic starts. Music resumes after. Same when the v6 is in rx or tx.
The menus and setup were easy. Now I'm 2020 adsb compliant.
I really wanted the Dynon because of the ability to load flight plans from fore flight but the $2,500 in additional product cost just wasn't worth it. If you interested call Matt directly.
Rynoth wrote:
Right now my only remaining issue is getting a correct RPM reading, but I think this has more to do with the RDAC than the iEfis lite. I just need to find the correct settings.
I'm pretty sure I've ready a few comments about RPM issues, but I think everyone eventually sorted it out. Hopefully it will be an easy fix for you.
Cheers,
Rusty
Users browsing this forum: Bing [Bot] and 3 guests
