by DCASonex » Thu Dec 31, 2015 9:51 am
I extended mine with a 5/8" thick spacer between hub and prop and made longer bushings. Did that mainly due to standard cowl was just too tight around Jabiru 3300. That 5/8" (16 mm) Greatly improves airflow around engine, especially back to oil cooler. Do need to carefully close off all leak paths so that ALL air that enters passes through fins to pick up heat. Doing that, have not needed to increase exit vents even with tapping off some air to cool mags, voltage regulator, and fuel pump. Secondary advantage of that type of prop spacer is precision made bushings are held square in reamed CNC bored holes in spacer and cannot wobble if bolts get a bit loose. I think Prince Propellers may sell a one piece spacer with integral bushings that may accomplish same.
One other factor to keep in mind is the effect of spiraling air from prop. with a Jabiru, or CAMit engine, it tends to throw air up and over cylinder #2, and down into #1. This effect is most noticeable in CHTs during climb at full power and low air speed. A dropped ceiling in left intake to keep air down and into #2 with similar clearance to what exists on cylinder #1 made all CHTs quite even. Rounding off leading top corner fins of #2 similar to what Sonex instructions call for on #1 also helps a bit. Final tweak was lowering ceiling of Sonex aluminum plenums by about 3/4" starting taper over cylinders #3 and 4. Simple plate baffles extending down from top might seem do same, but the resulting turbulence robs the air stream of momentum that creates the pressure differential across cylinder and head fins. With the Sonex or Jabiru supplied plenums, keeping the air moving with minimal turbulence is most effective. As an example of the effect of turbulence, for winter flying I place a couple of about 5/16" dia. (8 mm) round bars across to opening to cause a bit of turbulence and just that raises head temps sufficiently for winter. I also have a few small holes in ramps leading from intake to first cylinders to direct a small bit of air around underside of those cylinders that would otherwise be shielded in hopes of eliminating some potential hot spots. Note: For similar reasons, the gull wing baffles between cylinders should be on bottom as per Sonex instructions, not on top as per earlier Jabiru instructions.
