fastj22 wrote:Make sure the races are completely seated into the hubs. There should zero gap on the back side of the race. I used a large socket and tapped mine home with a small hammer. They change pitch when they get fully seated. You could use a press, but you won't get that ring when you get them seated.
13brv3 wrote:My spacers arrived today, and I pulled the wheels to finish driving the races in. The outer races were already bottomed out due to tightening the nut the other day, but the inside races weren't able to push in due to the fact that the brake disc bottomed out the pistons/pucks in the caliper. With the wheel off, it was easy to drive the inner races in. Adding a 1/8" spacer between the caliper and bearing works perfectly, and now the brakes are not bottomed out. The dust shields are now flush, and the races can't walk. This is how it should be :-)
Users browsing this forum: Bing [Bot] and 106 guests
